Component: GSM (BL0131) (E-blocks 2)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Category E-blocks 2
GSM (BL0131) component
Please click here to download the component source project: FC_Comp_Source_temp/EBlocks2_GSM_BL0131_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBlocks2_GSM_BL0131_2d.fcfx
AnswerIncomingCall
AnswerIncomingCall
Answers the phone for an incoming type call. Returns 0 for success and 255 for failure.
CheckForIncoming
CheckForIncoming
Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing
CheckNetworkStatus
CheckNetworkStatus
Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM.
DeleteAllMessages
DeleteAllMessages
Removes all pending text messages from the GSM module. Returns 0 for success and 255 for fail.
DialNumber
DialNumber
Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response.
- STRING Number
GetTextNumber
GetTextNumber
Collects the sender's phone number from an incoming text message.
- BYTE NumBytes
- STRING Return
GetTextString
GetTextString
Collects the text message data from an incoming text message.
- BYTE NumBytes
- STRING Return
HangUpCall
HangUpCall
Ends a voice based call. Returns 0 for success and 255 for failure.
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
ReadString
ReadString
Copies the data from the data string array to a local string variable
- BYTE NumBytes
- STRING Return
SendCommand
SendCommand
Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply
- STRING Command
- BYTE SendCR
SendScript
SendScript
Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE idx
SendString
SendString
Sends a string to the GSM module.
- STRING Text
SendTextMessage
SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure.
- STRING Number
- STRING Message
StringReceive
StringReceive
Attempts to receive a string from the GSM modem.
Expect Echo
Sets if we expect an echo of any data we send out to the GSM modem. Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
String Array Size
Amount of RAM memory to dedicate to receiving responces from the GSM
Message Array Size
Amount of RAM memory to dedicate to storing the last SMS message received by the GSM.
Script Count
Maximum number of scripts to store in the device's ROM
Script1
ASCII based AT command data stored in ROM and used when sending script 1
Port
With PIC target devices, only port avaible are B & C. If port A, D or E is slected then the port will default ot B or C.
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
Baud Options
Reset
Ring
Console Columns
Data Source
