Component: G Code Parser ()
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
G Code Parser component
A set of routines to allow a G-Code type file to be parsed a line at a time and the coordinates to be collected. Simulates the G commands via a simulation only 3D printer component but can also be used to pass values to actual hardware.
Please click here to download the component source project: FC_Comp_Source_temp/G-Code_Parser.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/G-Code_Parser.fcfx
GetAxis
Fc9-comp-macro.png GetAxis
Returns the value of the Axis generated from the ParseCommand function. 0 = Read X, 1 = Read Y, 2 = Read Z
Fc9-u8-icon.png - BYTE Axis
Specifies which axis to read 0/'x'/'X' - 1/'y'/'Y' - 2/'z'/'Z'
GetCoordinateMode
Fc9-comp-macro.png GetCoordinateMode
Returns the current coordinate mode. 0 = Absolute 1 = Relative
Fc9-comp-macro.png Initialise
Parse_G_Command
Fc9-comp-macro.png Parse_G_Command
Fc9-string-icon.png - STRING Command
Fc9-type-1-icon.png Bed Color
Fc9-type-1-icon.png Print Color
Fc9-type-21-icon.png Print Speed
Fc9-type-16-icon.png Print Type
Fc9-type-15-icon.png Print Size
Fc9-type-16-icon.png Print Shape
Fc9-conn-icon.png Max Print Dimensions
Fc9-type-21-icon.png X Width
Fc9-type-21-icon.png Y Length
Fc9-type-21-icon.png Z Height
