Component: RGB LED APA102C (LEDs)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category LEDs
RGB LED APA102C component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
Please click here to download the component source project: FC_Comp_Source_temp/LED_APA102C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_APA102C.fcfx
DrawCuboid3D
Fc9-comp-macro.png DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
Fc9-u8-icon.png - BYTE X1
Fc9-u8-icon.png - BYTE Y1
Fc9-u8-icon.png - BYTE Z1
Fc9-u8-icon.png - BYTE X2
Fc9-u8-icon.png - BYTE Y2
Fc9-u8-icon.png - BYTE Z2
Fc9-u8-icon.png - BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
Fc9-u8-icon.png - BYTE R
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
DrawLine2D
Fc9-comp-macro.png DrawLine2D
Draws a line on a 2D array of LEDs
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawLine3D
Fc9-comp-macro.png DrawLine3D
Draws a line on a 3D array of LEDs
Fc9-u16-icon.png - UINT Z1
Fc9-u16-icon.png - UINT Z2
DrawRectangle2D
Fc9-comp-macro.png DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
GetLEDColour
Fc9-comp-macro.png GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
Fc9-u16-icon.png - UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
Fc9-u8-icon.png - BYTE ColIdx
0 = R, 1 = G, 2 = B
GetLEDIndex2D
Fc9-comp-macro.png GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
LED Column to change the colour / Range: 0 to (LED Column - 1)
LED Row to change the colour / Range: 0 to (LED Row - 1)
GetLEDIndex3D
Fc9-comp-macro.png GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
Fc9-comp-macro.png Initialise
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the WS2801 ICs in the chain.
Refresh
Fc9-comp-macro.png Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
SetAllLEDColour
Fc9-comp-macro.png SetAllLEDColour
Sets the colour of all the LEDs in RAM
SetBrightness
Fc9-comp-macro.png SetBrightness
Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
Fc9-f32-icon.png - FLOAT Scaler
Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
SetBrightnessByte
Fc9-comp-macro.png SetBrightnessByte
Fc9-u8-icon.png - BYTE Scaler
Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
SetLEDColour
Fc9-comp-macro.png SetLEDColour
ShiftLEDs1D
Fc9-comp-macro.png ShiftLEDs1D
Shifts the LED colours in 1D and wraps
Fc9-u8-icon.png - BYTE Direction
0 = Forwards, 1 = Backwards
Fc9-u8-icon.png - BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
ShiftLEDs2D
Fc9-comp-macro.png ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
Fc9-s16-icon.png - INT X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
Fc9-s16-icon.png - INT Y
ShiftLEDs3D
Fc9-comp-macro.png ShiftLEDs3D
Fc9-s16-icon.png - INT Z
Fc9-conn-icon.png LED Properties
Fc9-type-16-icon.png LED Arrangement
Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
Fc9-type-21-icon.png LED Count
Total number of LEDs in the design
Fc9-type-15-icon.png Column Spacing
X Spacing Between LEDs on the Panel
Fc9-type-16-icon.png LED Current Usage
Fc9-type-16-icon.png Output Mode
Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O
Fc9-conn-icon.png Connection Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
