Component: Display Manager (Graphical Library)
| Author | MatrixTSL |
Display Manager component
Please click here to download the component source project: FC_Comp_Source_temp/Lib_DisplayManager.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Lib_DisplayManager.fcfx
The component can create the follow objects.
- Type_Line - 2 - A simple straight line.
- Type_Rectangle - 1 - A simple rectangular box.
- Type_RectangeFilled - 5 - A filled rectangular box.
- Type_Ellipse - 3 - A simple ellipse or circle.
- Type_EllipseFilled - 4 - A filled ellipse or circle.
- Type_TextBox - 0 - A text area allowing a line of text to be displayed.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Type_TextBox
An example showing the creation of some text areas inside formatted shapes.
CreateObject
DrawObject
| DrawObject | |
| Draws a single object onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro. | |
| ObjectID | |
MoveObject
| MoveObject | |
| Moves an existing object to absolute coordinates on the screen. | |
| ObjectID | |
| X | |
| Y | |
RedrawAll
| RedrawAll | |
| Redraws all the content from the display manager objects. Doesn't draw textfield components, this is done using the SetObjectText macro. | |
ScaleObject
| ScaleObject | |
| Changes the width and height of the selected Object | |
| ObjectID | |
| Width | |
| Height | |
SetObjectText
ShiftObject
| ShiftObject | |
| Shifts an existing object coordinates on the screen relative to the previous coordinates. | |
| ObjectID | |
| X | |
| Y | |
| Properties | |
| LinkTo | |
| Max Objects | |
| The total number of objects allowed on the screen. Sets the size of the RAM buffers used to track the various screen elements. | |
