Component: GLCD Bitmap Drawer ROM (Graphical Library)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.2
Category Graphical Library
GLCD Bitmap Drawer ROM component
A component to simplify the process of drawing bitmap images to a graphical display. Stores up to 10 bitmap images inside ROM based look up tables. Compatible with 24-bit / 256 Colour / 16 Colour / Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
Please click here to download the component source project: FC_Comp_Source_temp/Lib_Draw_Bitmap.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Lib_Draw_Bitmap.fcfx
The Bitmap Drawer component must be linked to the graphical LCD using the gLCD Object property.
Here is an example which loops drawing a monochrome and 24-bit bitmaps to the EBM001 graphical display.
FC6 Icon.png Bitmap Drawer Demo
The bitmap files used in the example can be found here.
ZIP Icon.png Bitmap Drawer Files
Here is another example which overlays several monochrome images to give the impression of animation. Shows a pair of eyes, which can randomly and momentarily look left, right or blink.
FC6 Icon.png Bitmap Drawer Demo 2
ZIP Icon.png Bitmap Drawer Files 2
Display_BMP
Fc9-comp-macro.png Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y.
Fc9-u8-icon.png - BYTE BitmapIndex
Selects from attached bitmaps. Range: 0-9
Fc9-u16-icon.png - UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
Fc9-u16-icon.png - UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
Fc9-u8-icon.png - BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
Fc9-u8-icon.png - BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Display_BMP_Fast
Fc9-comp-macro.png Display_BMP_Fast
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Attempts to draw a row at a time by not forcing coordinates for every pixel so may not work on some displays. Currently only supports colour displays.
GetHeight
Fc9-comp-macro.png GetHeight
Returns the height of the loaded bitmap file in pixels.
GetWidth
Fc9-comp-macro.png GetWidth
Returns the width of the loaded bitmap file in pixels.
SetTransparentColour
Fc9-comp-macro.png SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
Fc9-u8-icon.png - BYTE R
Fc9-u8-icon.png - BYTE G
Fc9-type-16-icon.png LinkTo
Fc9-type-7-icon.png ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
Fc9-type-21-icon.png ROM Bytes
Total number of ROM bytes used to store attached bitmap images.
Fc9-type-16-icon.png Number of Bitmaps
Number of bitmaps the component can store and draw to the LCD. Min 1 / Max 10
Fc9-conn-icon.png Bitmap 0
Fc9-type-13-icon.png Bitmap File
Bitmap file you wish to embed into the program. Compatible with .bmp files in the following formats: 24-Bit / 256 Colour / 16 Colour / Monochrome
Fc9-type-21-icon.png File Colour Depth
Number of bits per pixel. Currently the component only supports bitmap files with 1-bit or 24-bit colour depth.
Fc9-type-21-icon.png File Length
The number of bytes of ROM the bitmap file will consume. You can vie wthe number of ROM bytes available on your target device using the Device Helper component.
Fc9-type-21-icon.png File Width
Width of the bitmap file in pixels
Fc9-type-21-icon.png File Height
Height of the bitmap file in pixels
Fc9-type-21-icon.png Data Offset
Offset in the file where the bitmap pixel data starts
