Component: LIN Master (Comms: Interface)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 1.2
Category Comms: Interface
LIN Master component
Low level routines for controlling a LIN master (1.3 & 2.0) interface.
Please click here to download the component source project: FC_Comp_Source_temp/LinMasterV2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LinMasterV2.fcfx
Initialise the component
PowerDown
PowerDown
Power Down the device
SendMessageRxData
SendMessageRxData
Sends message with specified identifier and awaits a reply from a slave. Returns the number of data bytes received, 254 for a timeout or 255 for a checksum error.
- BYTE Identifier
6-Bit ID field, Range: 0x00 to 0x3F
- BYTE ChecksumType
0=Classic (LIN 1.3), 1=Enhanced (LIN 2.0)
- BYTE ResponseCount
Number of bytes to receive from the slave, Range: 0 to 8
- BYTE ResponseData
Data array to pass the received data
SendMessageTxData
SendMessageTxData
Sends a message to the slave along with data
- BYTE Identifier
- BYTE ChecksumType
- BYTE DataCount
Number of data bytes to transmit to the slave, Range: 0 to 8
- BYTE Data
Data array to send to the slave
UpdateBaud
UpdateBaud
Changes the UART Baud rate. 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
- BYTE new_baud
WakeUp
WakeUp
Wake Up the device
Bus Options
Baud Options
Receive Timeout
The number of milliseconds to wait for incoming data to be received from the slave.
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
CS
LIN bus chip select pin
Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
