Component: Digital Potentiometer (MCP41XXX / MCP42XXX) (Analog Output)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Category Analog Output
Digital Potentiometer (MCP41XXX / MCP42XXX) component
The MCP41XXX and MCP42XXX device range supports up to 2 digital potentiometer outputs. With 256 possible output resistance values for each channel.
Please click here to download the component source project: FC_Comp_Source_temp/MCP41xxx_42xxx_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/MCP41xxx_42xxx_Digital_Pot.fcfx
Startup the SPI peripheral ready for communications.
SetWiper
SetWiper
Sets the value of a single wiper
- BYTE Index
Range: 0-2 / 0=CH0, 1=CH1, 2=CH0 AND CH1
- BYTE Value
256 Taps Range: 0-255
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Device Properties
Number of Outputs
Number of Taps
Simulate Comms
