Component: SCADA (UART Dummy) (SCADA Slaves)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Category SCADA Slaves
SCADA (UART Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_temp/OLD_API_Slave_UART_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/OLD_API_Slave_UART_Dummy.fcfx
IOGetInputPin
IOGetInputPin
- BYTE Pin
Range: 0-13
- BOOL Return
IOSetOutputPin
IOSetOutputPin
- BYTE Pin
Range: 0-13
- BOOL State
Range: 0-1
UARTBaud
UARTBaud
- BYTE Rate
UARTCheckRX
UARTCheckRX
UARTInitialise
UARTInitialise
UARTReceive
UARTReceive
UARTSend
UARTSend
- BYTE Data
