Component: Sense Hat (Raspberry Pi Hat)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Category Raspberry Pi Hat
Sense Hat component
A component to drive various features on the Raspberry Pi Sense Hat. Supported Features: 8x8 RGB LED / 5-Way Joystick
Please click here to download the component source project: FC_Comp_Source_temp/RPI_SenseHat.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/RPI_SenseHat.fcfx
A simple example to sample the joystick and output a fixed colour to all 8 x 8 RGB LEDs. Pressing up on the joystick outputs blue to the LEDs and pressing down outputs red.
RPI Sense HAT
Initialises the I2C peripheral ready for communications.
ReadJoystick
ReadJoystick
Reads the joystick Returns the direction as a bit field. 1 = Down / 2 = Right / 4 = Up / 8 = Click / 16 = Left
SetAll
SetAll
Sets all pixels to a specific colour
- BYTE R
- BYTE G
- BYTE B
SetPixel
SetPixel
Seta the colour of a single pixel
- BYTE X
- BYTE Y
- BYTE R
- BYTE G
- BYTE B
I2C
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
API
