Component: Voice Recognition (V3) (Sensors)
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Category Sensors
Voice Recognition component
Module supporting up to 7 active voice commands controlled via a serial UART interface. Commands are trained into the module by the user so as to be speaker-dependent.
Please click here to download the component source project: FC_Comp_Source_temp/VoiceRecognitionELECHOUSEV3.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/VoiceRecognitionELECHOUSEV3.fcfx
These examples are designed to work with a 4D systems display pre-programmed with the VISI Genie runtime files. These files are also included in the example archives to allow you to easily replicate the project.
The 4D display can either be connected to the PC running Flowcode using the 4D USB cable or connected to an embedded Microcontroller using a hardware or software UART. If you are using the Flowcode simulation to communicate with the Visi component then be sure to set the Visi COM port property to the COM port assigned by Windows to the 4D USB Cable.
The Console window should also show some helpful information to aid in debugging any problems.
The first example demonstrates a simple rocker switch Visi component. RockerSwitch The second example demonstrates controlling the colour of an RGB LED using the Visi colour picker component. ColourPicker
Sets up the hardware UART to communicate with the module. Must be called before calling any of the other component macros. Returns 1 if communications to the module are successful else returns 0.
UART Properties
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Baud Options
Console Columns
Data Source
COM Port
Lists all the current available COM port hardware on your PC.
