Component: Drawing Area (Graphical Color)
Revision as of 12:04, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
Drawing Area component
Simulation runtime only graphical display component designed for SCADA operations. Allows easy pixel based displays and support for the GLCD libraries such as bitmap drawer and textfield.
Please click here to download the component source project: FC_Comp_Source_temp/glcd_SCADA.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/glcd_SCADA.fcsx
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawLineFast
Fc9-comp-macro.png DrawLineFast
DrawRectangle
DrawStart
Fc9-comp-macro.png DrawStart
FastPlot
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Range: 0-255
Fc9-u8-icon.png - BYTE Green
Range: 0-255
Fc9-u8-icon.png - BYTE Blue
Range: 0-255
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Range: 0-255
Range: 0-255
Range: 0-255
Window
Fc9-comp-macro.png Window
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
