Component: LED (5mm, Panel) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
LED (5mm, Panel) component
Standard 5mm LED mounted in a panel clip. Colour can be changed in component properties.
Please click here to download the component source project: FC_Comp_Source_temp/led_5mm_pnl.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/led_5mm_pnl.fcfx
