Component: File (RPI) (File)
Revision as of 12:19, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.7
Category File
File (RPI) component
File component allowing access to read and write files on the Raspberry Pi file system.
Please click here to download the component source project: FC_Comp_Source_temp/File_RPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/File_RPI.fcfx
AppendByteToFile
Fc9-comp-macro.png AppendByteToFile
Fc9-u8-icon.png - BYTE Data
AppendStringToFile
Fc9-comp-macro.png AppendStringToFile
Fc9-string-icon.png - STRING Data_String
CloseFile
Fc9-comp-macro.png CloseFile
CreateFile
Fc9-comp-macro.png CreateFile
DeleteFile
Fc9-comp-macro.png DeleteFile
MoveToNextFileSector
Fc9-comp-macro.png MoveToNextFileSector
Not currently implemented on the RPI
Fc9-u8-icon.png - BYTE ForceNextSector
OpenFile
Fc9-comp-macro.png OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
8.3 filename of the file we are trying to open e.g. "file.txt"
OpenFolder
Fc9-comp-macro.png OpenFolder
Fc9-string-icon.png - STRING Folder_Name
ReadByteFromFile
Fc9-comp-macro.png ReadByteFromFile
Reads a byte from the currently open file. Auto increments the position in the file. A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
ReadByteFromIndex
Fc9-comp-macro.png ReadByteFromIndex
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer.
Fc9-u32-icon.png - ULONG Address
ReadFileLength
Fc9-comp-macro.png ReadFileLength
Fc9-s16-icon.png - INT Return
ReadFileSize
Fc9-comp-macro.png ReadFileSize
Reads the entire size of the current file in bytes.
Fc9-u32-icon.png - ULONG Return
ReadStringFromFile
Fc9-comp-macro.png ReadStringFromFile
Reads a string from the currently open file. Auto increments the position in the file. An empty string signifies the end of the file has been reached.
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to attempt to read
Fc9-u8-icon.png - BYTE EndChar
Ends the string if the value specified is found, default is 0
SetFileIndex
Fc9-comp-macro.png SetFileIndex
Fc9-u8-icon.png - BYTE File_Index
Range: 0 to 4
WriteByteToBuffer
Fc9-comp-macro.png WriteByteToBuffer
Fc9-u16-icon.png - UINT Address
WriteFileSector
Fc9-comp-macro.png WriteFileSector
Fc9-type-10-icon.png Root Folder
Root location on the RPI where the files will be stored
Fc9-type-21-icon.png File Count
Number of simultaneous files we want to access.
Fc9-conn-icon.png Simulation
Fc9-type-20-icon.png Sim Root Folder
