Component: GLCD (ILI9488) (Graphical Color)
Revision as of 12:19, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Graphical Color
GLCD (ILI9488) component
Graphical display component designed to work with the ILI9488 controller IC Based on the ILI9488 16-bit colour graphical controller IC. Supports Serial, 8-bit and 16-bit interface modes.
Please click here to download the component source project: FC_Comp_Source_temp/GLCD_ILI9488.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/GLCD_ILI9488.fcfx
BPlot
BPlot
- UINT X1
- UINT Y1
BacklightOff
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BacklightOn
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
LCD_Write_Data8
LCD_Write_Data8
- BYTE data
LCD_Write_Reg
LCD_Write_Reg
- BYTE data
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
Flip X
Flips the horizontal display axis in hardware.
Flip Y
Flips the vertical display axis in hardware.
Colour
Monochrome
Foreground Color
Background Color
Invert Colour
No: A set output will light the corresponding LED Yes: A clear output will light the corresponding LED
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Connection Type
Write (WR)
Read (RD)
Toggle CS
Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Chip Select (CS)
Chip select pin connection
Reg Select (D/C)
Use Ports
Allows the 8-bit or 16-bit data to be controlled using 8-bit ports. Yes - Ports will be used allowing for better data rates No - individual I/O pins will be used allowing for better flexibility
Data0
Data1
Data2
Data3
Data4
Data5
Data6
Data7
Reset
Reset pin connection
Use Backlight Pin
LED
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
