| Author
Matrix Ltd
| Version
1.3
| Category
Graphical Monochrome
GLCD (TLS8201) component
A Graphical LCD component to drive displays fitted with a TLS8201 controller IC.
Please click here to download the component source project: FC_Comp_Source_temp/GLCD_TLS8201.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/GLCD_TLS8201.fcfx
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
| Specifies the colour of the background.
- BYTE
Pixel_Colour
| 0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
| Specifies the colour of the foreground.
- BYTE
Pixel_Colour
| 0=White, 1=Black
Write_Command
Write_Command
- BYTE
Command
Write_Data
Write_Data
- BYTE
Data
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Pin
| Data Pin Connection
Clock Pin
| Clock Pin Connection
A0 Pin
| A0 Pin Connection
CS Pin
| Chip Select Pin Connection
Reset
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
