Component: LED Mono (LED)
Author | Matrix TSL |
Version | 1.0 |
Category | LED |
LED Mono component
Please click here to download the component source project: FC_Comp_Source_temp/LED_Mono_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_Mono_2dgi.fcfx
Here is an example Flowcode program to read the value of a switch and change the state of LED accordingly.
LED Example
SetState
SetState |
Sets the state of the LED, accounting for the polarity. | |
State |
1=On, 0=Off | |
Return |
TurnOff
TurnOff |
Return |
TurnOn
TurnOn |
Return |
