Exercise - Create an LED Component
- Open a new Flowcode flowchart.
- Make sure that the System Panel is visible. If not, then click on 'View / System Panel'.
- Make sure that Panel Properties are visible. If not, then click on 'View / Panel Properties'.
- Click on the hemisphere in the Shapes menu and drag it onto the Systems Panel.
- Right-click and select 'Center all objects' from the menu.
- Click on the hemisphere to select it. A blue dotted square appears around it.
- Change the name of the component to 'LEDcomponent'.
- To do this, find the 'handle' of the component at the top of the Panel Properties. Click on the name 'shape' (the default name) and change it to 'LEDcomponent'.
