Component: MIAC AllCode API (dsPIC) (AllCode)
| Version | 1.1 |
| Category | AllCode |
- 1 MIAC AllCode API (dsPIC) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CardCreate
- 5.2 CardDelete
- 5.3 CardInserted
- 5.4 CardOpen
- 5.5 CardReadByte
- 5.6 CardWriteByte
- 5.7 CommsBaud
- 5.8 CommsRead
- 5.9 CommsWrite
- 5.10 GetAPIVersion
- 5.11 LCDBacklight
- 5.12 LCDBitmap
- 5.13 LCDClear
- 5.14 LCDCursor
- 5.15 LCDLine
- 5.16 LCDNumber
- 5.17 LCDOptions
- 5.18 LCDPixel
- 5.19 LCDPrint
- 5.20 LCDRect
- 5.21 LCDVerbose
- 5.22 PWMConfig
- 5.23 PWMDuty
- 5.24 PWMEnable
- 5.25 ReadAnalogInput
- 5.26 ReadDigitalInput
- 5.27 ReadInputs
- 5.28 ReadKey
- 5.29 ReadRTC
- 5.30 WriteRTC
- 5.31 WriteRelay
- 5.32 WriteRelays
- 5.33 WriteTran
- 5.34 WriteTrans
- 6 Property reference
MIAC AllCode. dsPIC version of the MIAC loaded with the AllCode firmware. Usefull for SCADA, Control or Test applications. Allows you to control the MIAC using the programming language of choice. Compatible with simulation / Bluetooth / Wifi / RS232 and RS485
Please click here to download the component source project: FC_Comp_Source_temp/MIAC_AllCode_Component_Source.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/MIAC_AllCode_Component_Source.fcsx
CardCreate
| CardCreate | |
| Attempts to create a specific file on the card. Returns 0 for success, 255 for no card or error. | |
| Filename | |
CardDelete
| CardDelete | |
| Attempts to delete a specific file on the card. Returns 0 for success, 255 for no card or error. | |
| Filename | |
CardInserted
| CardInserted | |
| Checks to see if a card is present. Returns 0 for no card or 1 for card detected | |
CardOpen
| CardOpen | |
| Attempts to open a specific file from the card. Returns 0 for file found and opened, 239 for file not found and 255 for no card. | |
| Filename | |
CardReadByte
| CardReadByte | |
| Reads a byte from the open file. | |
CardWriteByte
| CardWriteByte | |
| Appends a byte to the end of the open file. Returns 0 for success. | |
| data | |
CommsBaud
| CommsBaud | |
| Sets the Baud rate of the alt communications channel | |
| Baud | |
| Range: 0-7 : 0=1200 / 7=115200 | |
CommsRead
| CommsRead | |
| Reads a byte from the alt communications channel | |
| Timeout | |
| Range: 0-255 : 0 = Don't wait / 1-255 = ms | |
CommsWrite
| CommsWrite | |
| Writes a byte to the alt communications channel | |
| Data | |
| Range: 0-255 | |
GetAPIVersion
| GetAPIVersion | |
| Gets the API version of the Robot ARM Firmware | |
LCDBacklight
| LCDBacklight | |
| Controls the brightness of the LCD backlight. | |
| Brightness | |
| Range: 0-100 | |
LCDBitmap
| LCDBitmap | |
| Draws a bitmap file from the SD card onto the MIAC display | |
| X | |
| Range: 0-119 | |
| Y | |
| Range: 0-49 | |
| Filename | |
| Range: 0-1 | |
LCDClear
| LCDClear | |
| Clears the MIAC display | |
LCDCursor
| LCDCursor | |
| Sets the cursor position for the MIAC display | |
| X | |
| Range: 0-21 | |
| Y | |
| Range: 0-4 | |
LCDLine
| LCDLine | |
| Draws a single pixel width line on the MIAC display | |
| X1 | |
| Range: 0-119 | |
| Y1 | |
| Range: 0-49 | |
| X2 | |
| Range: 0-119 | |
| Y2 | |
| Range: 0-49 | |
LCDNumber
| LCDNumber | |
| Prints a number to the MIAC display starting from the current cursor position. | |
| Value | |
| Range: -32678 - 32767 | |
LCDOptions
| LCDOptions | |
| Controls some of the LCD options | |
| Foreground | |
| Range: 0-1 | |
| Background | |
| Range: 0-1 | |
| Transparent | |
| Range: 0-1 | |
LCDPixel
| LCDPixel | |
| Controls a single pixel on the MIAC display | |
| X | |
| Range: 0-119 | |
| Y | |
| Range: 0-49 | |
| State | |
| Range: 0-1 | |
LCDPrint
| LCDPrint | |
| Prints a string to the MIAC display starting from the current cursor position. | |
| data | |
| Range: 0-21 | |
LCDRect
| LCDRect | |
| Draws a single pixel rectangle on the MIAC display | |
| X1 | |
| Range: 0-119 | |
| Y1 | |
| Range: 0-49 | |
| X2 | |
| Range: 0-119 | |
| Y2 | |
| Range: 0-49 | |
LCDVerbose
PWMConfig
PWMDuty
| PWMDuty | |
| Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535 | |
| Channel | |
| Range 0-5 | |
| Duty | |
PWMEnable
ReadAnalogInput
| ReadAnalogInput | |
| Reads a single digital input. | |
| Channel | |
ReadDigitalInput
| ReadDigitalInput | |
| Channel | |
ReadInputs
| ReadInputs | |
| Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7 | |
ReadKey
| ReadKey | |
| Reads a keypress from the keypad. | |
ReadRTC
| ReadRTC | |
| Reads a value from the real time clock module. Used for getting the time or date. | |
| Unit | |
| 0=Second 1=Minute 2=Hour 3=Day 4=Month 5=Year | |
WriteRTC
| WriteRTC | |
| Writes a value to the real time clock module. Used for setting the time or date. | |
| Unit | |
| Value | |
WriteRelay
| WriteRelay | |
| Allows a single relay to be switched on or off. | |
| Channel | |
| Range 1-4 | |
| Value | |
| 0 = Off, 1 = On | |
WriteRelays
| WriteRelays | |
| Allows all relays to be switched on or off in a single command. | |
| Value | |
| Range: 0-15 or 0b0000 to 0b1111 | |
WriteTran
| WriteTran | |
| Allows a single transistor output to be switched on or off. | |
| Channel | |
| Range 1-4 | |
| Value | |
| 0 = Off, 1 = On | |
WriteTrans
| WriteTrans | |
| Allows all transistor outputs to be switched on or off in a single command. | |
| Value | |
| Properties | |
| Connections | |
| Operating Mode | |
| API Connection Type | |
| API connection mode. COM - Bluetooth / RS232 / RS485 WIFI - Network | |
| Auto Detect | |
| Baud | |
