Component: DC Motor ()
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 1.2 |
| Category |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here to download the component source project: FC_Comp_Source_temp/Motor_with_reverse.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Motor_with_reverse.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels.
Motors
Break
| Break | |
| Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
Coast
| Coast | |
| Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
Disable
| Disable | |
| Disable the motor output | |
Enable
| Enable | |
| Enables the motor output | |
Forwards
| Forwards | |
| Set the motor turning in the forwards direction by setting the pins according to the 'Reverse Pattern' property. | |
| Duty | |
| Sets the motor power for PWM or H-Bridge outputs | |
Reverse
| Reverse | |
| Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
| Duty | |
