Component: WLAN (EB069-00-2, RN171) (RN171) (Wireless)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 1.1 |
Category | Wireless |
WLAN (EB069-00-2, RN171) component
Wireless LAN component designed to work with the RN171 module from Microchip. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069-00-2 E-block.
Please click here to download the component source project: FC_Comp_Source_temp/WLAN-RN171_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/WLAN-RN171_Dummy.fcfx
Simple playback example - allows a wav file to be streamed out using PWM. Repeats the playback in a loop.
Simple recording example - allows a wav file to be recorded from a microphone connected to an ADC input pin. Records for approx 10 seconds.
CheckForPageRequests
CheckForPageRequests |
To be called periodically. Returns non-zero if a request has been processed | |
Return |
ConnectToSSID
ConnectToSSID |
Attempts to connect to the given SSID and Key values. Returns 0 if successful. | |
SSID |
Key |
Return |
DisableCommandMode
DisableCommandMode |
Exits command mode | |
Return |
EnterCommandMode
EnterCommandMode |
Attempts to leave data mode and enter command mode | |
Return |
GetInValue
GetInValue |
Returns the string value of a Request parameter | |
index |
Index of the request paramter, starting at zero. | |
Return |
GetReply
GetReply |
Returns the last received response to a command. 0 = OK 1 = FAIL_ERR 2 = STX_ERR 3 = CMD_ERR 4 = PARAM_ERR 5 = ETX_ERR 6 = SERIAL 255 = TOUT | |
Return |
Initialise |
Initialise the device with the property data. Returns 0 if successful | |
Return |
ReadConnectionStatus
ReadConnectionStatus |
Checks the connection status. Returns 0 if not connected, 1 if connected. | |
Return |
ReceiveIncoming
ReceiveIncoming |
Returns the received data string | |
Return |
SendCommand
SendCommand |
Sends the given command and returns the reply status. (See GetReply for return values) | |
Command |
Return |
SendString
SendString |
Sends the given Text. Appends a CR/LF pair of characters it CrLf is true. | |
Text |
CrLf |
Return |
SetOutValue
SetOutValue |
Set the value of an outbound substitution string | |
index |
value |
Return |
Properties |
