| Author | Matrix Ltd |
| Version | 1.6 |
| Category | Graphical Color |
Drawing Area component
Simulation runtime only graphical display component designed for SCADA operations. Allows easy pixel based displays and support for the GLCD libraries such as bitmap drawer and textfield.
Please click here to download the component source project: FC_Comp_Source_temp/glcd_SCADA.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/glcd_SCADA.fcsx
BPlot
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
ClearDisplay
|   | ClearDisplay |
|  - VOID | Return |
DrawCircle
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Transparent |
|  - BYTE | Solid |
|  - VOID | Return |
DrawEllipse
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
DrawLine
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
DrawLineFast
|   | DrawLineFast |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
DrawRectangle
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
DrawStart
|   | DrawStart |
|  - VOID | Return |
FastPlot
|   | FastPlot |
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0. |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
Plot
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
Print
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - VOID | Return |
SetBackgroundColour
|   | SetBackgroundColour |
| Specifies the colour of the background by creating a mixture of red, green and blue. |
|  - BYTE | Red |
| Range: 0-255 |
|  - BYTE | Green |
| Range: 0-255 |
|  - BYTE | Blue |
| Range: 0-255 |
|  - VOID | Return |
SetDisplayOrientation
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
SetFontScaler
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
SetForegroundColour
|   | SetForegroundColour |
| Specifies the colour of the foreground by creating a mixture of red, green and blue. |
|  - BYTE | Red |
| Range: 0-255 |
|  - BYTE | Green |
| Range: 0-255 |
|  - BYTE | Blue |
| Range: 0-255 |
|  - VOID | Return |
Window
|   | Window |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | Properties |
|   | Dimensions |
|   | Pixel Height |
|   | Pixel Width |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Colour Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation Mode |
|   | Display Method |
| Chooses which method to use when drawing to the gLCD component The bitmap is the more common mode but may run slowly on some machines. The point cloud should run faster but may use more memory. |
