Component: Air Quality (BME688) (Environmental)
Revision as of 13:08, 7 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Environmental
Air Quality (BME688) component
An air quality sensor connected using a standard I2C bus. Capable of detecting indoor and outdoor air quality including CO2 H2 VOCs and VSCs.
Please click here to download the component source project: FC_Comp_Source_BME688_AirQualitySensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BME688_AirQualitySensor.fcfx
The App Developer (Arduino Mega) component allows an Arduino Mega board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Mega hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
Arduino Mega App Developer Firmware
The COM port to the Arduino hardware is selected via the SCADA_Ard_Mega component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
Device Port Pin E0 E1 E2 E5 G5 E3 H3 H4 H6 H6 B4 B5 B6 B7 J1 J0 H1 H0 D3 D2 D1 D0 A0 A1 A2 A3 A4 A5 A6 A7 C7 C6 C5 C4 C3 C2 C1 C0 D7 G2 G1 G0 L7 L6 L5 L4 L3 L2 L1 L0
Arduino Style Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
App Developer Slave Analogue Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Device Port Pin F0 F1 F2 F3 F4 F5 F6 F7 K0 K1 K2 K3 K4 K5 K6 K7
Arduino Style Pin A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15
App Developer Slave Peripheral Pin I2C 0 SDA I2C 0 SCL SPI 0 MOSI SPI 0 MISO SPI 0 SCK UART 0 RX UART 0 TX UART 1 RX UART 1 TX UART 2 RX UART 2 TX PWM 0 PWM 1 PWM 2 PWM 3 PWM 4 PWM 5 PWM 6 PWM 7 PWM 8 PWM 9 PWM 10 PWM 11 PWM 12 PWM 13 PWM 14 PWM 15
Device Port Pin D1 D0 B3 B4 B5 D2 D3 H0 H1 J0 J1 B7 G5 B5 B6 B7 B4 H6 E3 E4 E5 H3 H4 H5 L3 L4 L5
Arduino Style Pin D20 D21 D50 D10 D11 D19 D18 D17 D16 D15 D14 D13 D4 D11 D12 D13 D10 D9 D5 D2 D3 D6 D7 D8 D46 D45 D44
Initialises the I2C bus and sets up the device ready for operation. Returns 1 if the device has been found and is communicating.
- BOOL Return
PerformGasResistanceCycle
Performs a forced heating cycle. Returns 1 for a successful cycle. Returns 0 if the heating time was not enough or the temperature was too high to reach.
- FLOAT Temperature
Temperature in Celcius we want to reach, typically between 200 and 400�C
- UINT Duration
Step duration in milliseconds, default 30 - Range: 1 to 4032
- BOOL Return
ReadGasResistance
ReadGasResistance
Reads the resistance of the gas in ohms from the last heating cycle.
- FLOAT Return
ReadHumidity
ReadHumidity
Collects the humidity and returns as a floating point value in percent.
- BYTE Index
Forced Mode = 0 / Parallel Mode = 0-2
- FLOAT Return
ReadPressure
ReadPressure
Collects the pressure and returns as a floating point value in pascal.
- BYTE Index
- FLOAT Return
ReadRegister
ReadRegister
A simple example showing a generic way to read a register using I2C.
- BYTE Address
ReadTemperature
ReadTemperature
Collects the temperature and returns as a floating point value in degrees C.
- BYTE Index
- FLOAT Return
SetMode
SetMode
Sets the mode of the sensor to low power sleep, forced or parallel
- BYTE Mode
0=Sleep, 1=Forced, 2=Parallel
WriteRegister
WriteRegister
A simple example showing a generic way to write a register using I2C.
- BYTE Address
- BYTE Data
I2C Properties
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Options
Device Address
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
Comms Simulation
Injector
