Component: CNC Machine (Scenarios)
Jump to navigationJump to search| Author | Matrix |
| Category | Scenarios |
CNC Machine component
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
Please click here to download the component source project: FC_Comp_Source_CNCComponent_v002.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CNCComponent_v002.fcfx
Drill_Speed
| Drill_Speed | |
| Will cause the drill to rotate according to the speed. If no speed is set it will stay static. | |
| DrillSpeed | |
| Speed of the Drill. 0=Stopped | |
HomeMachine
| HomeMachine | |
| Moves the machine an axis at a time until the end stop is hit. Finishes by resetting the coordinates to 0,0,0. | |
| Enables the three motors within the component allowing for movement when any of the Axis macros are called. | |
MoveToXYZ
| MoveToXYZ | |
| Moves the tool on the machine to the absolute X Y Z position specified at the speed specified by performing 3D linear interolation. | |
| X | |
| Y | |
| Z | |
ResetCoordinates
| ResetCoordinates | |
| Resets the coordinates to the home position 0,0,0. | |
XAxisMovement
YAxisMovement
ZAxisMovement
| Properties |
