Component: Bluetooth (BL0170) (E-blocks 2)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.3
Category E-blocks 2
Bluetooth component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Bluetooth_RN4677_BL0170.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Bluetooth_RN4677_BL0170.fcfx
ConnectToMAC
Fc9-comp-macro.png ConnectToMAC
Connects to a specific Bluetooth MAC address. Waits up to 5 seconds for connection to be established. Returns 1 if connection was successful.
Fc9-string-icon.png - STRING MACAddress
EnterCommandMode
Fc9-comp-macro.png EnterCommandMode
Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK
GetMACAddress
Fc9-comp-macro.png GetMACAddress
Gets the local Bluetooth device MAC address.
Fc9-comp-macro.png Initialise
Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply.
LeaveCommandMode
Fc9-comp-macro.png LeaveCommandMode
Leaves command mode allowing data to be passed back and forth,
ReadString
Fc9-comp-macro.png ReadString
Copies the incoming data from the data string array to a local string variable.
Fc9-u8-icon.png - BYTE NumBytes
Maximum number of bytes to try and read
ReceiveByte
Fc9-comp-macro.png ReceiveByte
Receives a single data byte from the Bluetooth module. 0-255 signifies valid data / 256 signifies no data available.
Fc9-u16-icon.png - UINT Timeout
Amount of time to wait in milliseconds 0=Wait forever
ReceiveCount
Fc9-comp-macro.png ReceiveCount
Returns the number of bytes currently sat waiting in the receive buffer.
SendByte
Fc9-comp-macro.png SendByte
Sends a single data byte out to the Bluetooth module.
Fc9-u8-icon.png - BYTE Data
SendCommand
Fc9-comp-macro.png SendCommand
Sends a command string to the Bluetooth module. Returns: 0 = No Reply / 1 = Command sent ok
Fc9-string-icon.png - STRING Command
Fc9-u8-icon.png - BYTE SendCR
Fc9-u8-icon.png - BYTE DiscardReply
0=Do not touch the reply, 1=Wait for reply and remove from buffer
SendString
Fc9-comp-macro.png SendString
Sends a string to the Bluetooth module.
WaitForStringValue
Fc9-comp-macro.png WaitForStringValue
Allows us to wait and check for an incoming value. Returns 1 if the string value is found otherwise returns 0.
Fc9-string-icon.png - STRING Value
String value to look for
Length of time to wait in milliseconds
Fc9-conn-icon.png Bluetooth Settings
Fc9-type-10-icon.png Device Name
Sets the friendly name of the Bluetooth device.
Fc9-type-10-icon.png Pair Key
Fc9-type-7-icon.png Discoverable
Is the Bluetooth module discoverable by default?
Fc9-type-21-icon.png Reply Timeout
Specifies the amount of time to wait for incoming data before timing out in milliseconds. Default 2000 = 2 seconds.
Fc9-type-14-icon.png RX Buffer Size
Amount of RAM memory to dedicate to receiving responses and incoming data from the BT module. Default 40
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-16-icon.png TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Fc9-conn-icon.png Simulation
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
