Component: LED (BL0167) (E-blocks 2)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
LED component
LED component to drive the E-blocks 2 BL0167 LED board. Provides eight individually addressable LEDs.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_LED_BL0167.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_LED_BL0167.fcfx
AllOff
AllOff
Switches Off All LEDs.
AllOn
AllOn
Switches On All LEDs.
BarGraph
BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
- BYTE Length
How many items to light up. Range 0-8
LEDOff
LEDOff
Turns off the selected LED leaving the other LEDs as was.
- BYTE Index
LED to switch off. Range: 0-7
LEDOn
LEDOn
Turns on the selected LED leaving the other LEDs as was.
- BYTE Index
LED to switch on. Range: 0-7
PointGraph
PointGraph
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range.
- BYTE Index
The LED to light. Range: 0-7
WriteValue
WriteValue
Write a number which is presented on the LEDs in binary.
- BYTE Value
Value to write to the LEDs. Range: 0-255
Output Mode
Port
Colour
