Component: Electrical Machines (AllCode)
| Version | 2.0 |
| Category | AllCode |
- 1 Electrical Machines component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Get3PhaseMode
- 5.2 GetAPIVersion
- 5.3 GetAbsPosition
- 5.4 GetCommsOK
- 5.5 GetControlFeedback
- 5.6 GetControlOutputs
- 5.7 GetCurrent
- 5.8 GetDataArray
- 5.9 GetErrorStatus
- 5.10 GetLogData
- 5.11 GetLogDataReady
- 5.12 GetLogStartAngle
- 5.13 GetMotorDirection
- 5.14 GetRPM
- 5.15 GetSafetySwitch
- 5.16 GetVoltage
- 5.17 GetWeight
- 5.18 Initialise
- 5.19 SetAbsPosition
- 5.20 SetActive
- 5.21 SetCapacitorBank
- 5.22 SetControlKD
- 5.23 SetControlKI
- 5.24 SetControlKP
- 5.25 SetControlMaxDrivePercentage
- 5.26 SetControlSetpoint
- 5.27 SetDriveMode
- 5.28 SetDynoLoad
- 5.29 SetFan
- 5.30 SetFrequency
- 5.31 SetLoadCellCalibration
- 5.32 SetMotorDirection
- 5.33 SetMotorType
- 5.34 SetTCPProps
- 5.35 SetThreePhaseDriveMode
- 5.36 SetVoltage
- 5.37 ZeroLoadCell
- 6 Property reference
A set of functions to communicate with the Matrix EM hardware. Allows the functions to be easily standardised across all SCADA programs.
Please click here to download the component source project: FC_Comp_Source_EM_Functions.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_EM_Functions.fcsx
Get3PhaseMode
| Get3PhaseMode | |
| Checks to see if the brushless mode is enabled | |
GetAPIVersion
| GetAPIVersion | |
| Reads the API firmware version | |
GetAbsPosition
| GetAbsPosition | |
| Reads the absolute position of the encoder | |
GetCommsOK
| GetCommsOK | |
| Checks if comms are ok and stable | |
GetControlFeedback
| GetControlFeedback | |
GetControlOutputs
| GetControlOutputs | |
| Data | |
GetCurrent
| GetCurrent | |
| Reads the current of a single channel | |
| Channel | |
| Range: 0-6 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=Dyno, 6=I, 7=TotalDriver | |
GetDataArray
GetErrorStatus
GetLogData
| GetLogData | |
| Gets a 64-byte packet of log data. 250 packets make up a single log. Returns 0 if comms failed and 1 if comms OK | |
| Buffer | |
| Buffer to store the incoming log data | |
GetLogDataReady
| GetLogDataReady | |
| Checks to see if the logging is complete and ready to read. | |
GetLogStartAngle
| GetLogStartAngle | |
| Collects the U Phase angle at the start of logging. Used to calculate and re-create the 3Phase voltage data. | |
GetMotorDirection
| GetMotorDirection | |
| Reads the motor direction | |
GetRPM
| GetRPM | |
| Reads the speed in RPM | |
GetSafetySwitch
| GetSafetySwitch | |
| Reads the safety switch | |
GetVoltage
| GetVoltage | |
| Reads the voltage of a single channel | |
| Channel | |
| Range: 0-5 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=VEXT | |
GetWeight
| GetWeight | |
| Scale | |
| Range: 0-1 - 0=Weight, 1=Torque | |
| Returns 1 if the connection is ok and communications have been established | |
| MotorType | |
| 0=DC, 1=1Phase, 2=3Phase, 3=AngleControl | |
SetAbsPosition
| SetAbsPosition | |
| Resets the absolute motor position to 0 | |
SetActive
| SetActive | |
| Active | |
| 0=Off, 1=On | |
SetCapacitorBank
| SetCapacitorBank | |
| Cap | |
SetControlKD
| SetControlKD | |
| Value | |
SetControlKI
| SetControlKI | |
| Value | |
SetControlKP
| SetControlKP | |
| Value | |
| SetControlMaxDrivePercentage | |
| Value | |
| Range 0.0-1.0 | |
SetControlSetpoint
| SetControlSetpoint | |
| Value | |
SetDriveMode
| SetDriveMode | |
| Mode | |
| 0=PWM, 1=On/Off/Float | |
SetDynoLoad
| SetDynoLoad | |
| Load | |
SetFan
| SetFan | |
| |Sets the speed of the FAN from 0 (MIN) to 3000 (MAX) | |
| Speed | |
SetFrequency
| SetFrequency | |
| Frequency | |
| Frequency of sine wave in Hz | |
| SetLoadCellCalibration | |
| Value | |
SetMotorDirection
| SetMotorDirection | |
| MotorDirection | |
| 0=FW, 1=BW | |
SetMotorType
| SetMotorType | |
| MotorType | |
| 0=DC, 1=1 Phase, 2=3 Phase | |
SetTCPProps
| SetTCPProps | |
| Sets the TCP IP address and Port | |
| IP0 | |
| IP1 | |
| IP2 | |
| IP3 | |
| Port | |
| SetThreePhaseDriveMode | |
| Mode | |
| 0=Simple, 1=Accurate | |
SetVoltage
| SetVoltage | |
| Sets the DC Voltage from 0 to 24V | |
| Voltage | |
| Index | |
ZeroLoadCell
| ZeroLoadCell | |
