Component: ADC (MCP356X) (Analog Input)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Analog Input
ADC (MCP356X) component
An external ADC featuring 2, 4, or 8 channel 24-bit input. Capable of reading each channel independently or in differential mode. Communication using an SPI bus up to 20MHz.
Please click here to download the component source project: FC_Comp_Source_ExternalADC_MCP356X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ExternalADC_MCP356X.fcfx
Fc9-comp-macro.png Initialise
Confgures the SPI bus ready for communications and initialises the MCP356X device. Returns true if device is responding to commands.
SampleADC
Fc9-comp-macro.png SampleADC
Performs a single ADC sample and returns the result as a 24-bit value
Fc9-u8-icon.png - BYTE PositiveChannel
0=CH0 - 7=CH7, 8=GND, 9=VDD, 11=REF+, 12=REF-, 13=TP, 14=TM, 15=VCM
Fc9-u8-icon.png - BYTE NegativeChannel
SetGainCalibration
Fc9-comp-macro.png SetGainCalibration
Allows the device offset to be entered allowing for accurate readings.
Fc9-u32-icon.png - ULONG Gain
Default 800000 = Gain of 1X
SetOffsetCalibration
Fc9-comp-macro.png SetOffsetCalibration
Fc9-s32-icon.png - LONG Offset
Fc9-conn-icon.png Device Configuration
Fc9-type-16-icon.png Device Type
Fc9-type-16-icon.png Device Address
These bits are fixed from the manufacturer and by default are 01. Used as Bits 6 and 7 of the command byte. Alternative bits must be requested from the manufacturer.
Fc9-type-16-icon.png Clock Selection
Fc9-type-16-icon.png Sensor Bias Current
Fc9-type-16-icon.png ADC Bias Current
Fc9-type-16-icon.png AMCLK Prescaler
Fc9-type-16-icon.png Oversampling Ratio
Fc9-type-16-icon.png ADC Gain
Fc9-type-16-icon.png IRQ Mode
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png CS / SS
Fc9-type-7-icon.png Use IRQ
No: Use polling of the status register to determine when an ADC sample is complete. Yes: Use the IRQ interrupt pin to determine when an ADC sample is complete.
Fc9-conn-icon.png Simulation
No: Simulation is done using panel sliders. Yes: Send SPI data via API interface and show real time data using panel sliders.
