Component: Accel / Mag 6-Axis (LSM303D) (Movement Orientation)
Revision as of 13:12, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Movement Orientation
Accel / Mag 6-Axis (LSM303D) component
LSM303D Combined 6-Axis Accelerometer and Magnetometer sensors Useful for working out data such as Pitch and Yaw.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_LSM303D.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_LSM303D.fcfx
CollectXYZData
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE Axis
- INT Return
Sets up up the communication bus and initialises the accelerometer module. Returns 1 for success and 0 for fail.
Read_Bearing
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE NumSamples
The number of readings to base the bearing on
Read_Register
Read_Register
Reads a value from a register on the accelerometer.
- BYTE Reg
SimReset1G
SimReset1G
SimSetAccelerometer
SimSetAccelerometer
Allows the XYZ slider values to be set via the simulation
- INT X
- INT Y
- INT Z
SimSetCompass
SimSetCompass
- INT X
- INT Y
- INT Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
UpdateCompassData
UpdateCompassData
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Write_Register
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE Reg
- BYTE Data
Bit Depth
Accel Data Rate
Accel Scale
Compass Data Rate
Compass Scale
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Simulate Comms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the I2C CAL component - Injector etc
