Component: Modbus TCP Master (Comms: System)
Revision as of 13:12, 7 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.1
Category Comms: System
Modbus TCP Master component
Modbus component for talking to Modbus compatible hardware via Ethernet or WIFI. Ensure TCP/IP or WIFI component is initialised and connected to a network before calling the ModbusMasterTCP component macros.
Please click here to download the component source project: FC_Comp_Source_ModbusTCP.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ModbusTCP.fcfx
Example master program to control the slave. The example sets coil address 0, clears coil address 0, reads an input register and outputs to the LCD. Be sure to set the IP address of the slave device at the top of the program. If you are simulating then use the IP address of the PC running the Slave simulation. Both programs can be simulated on the same PC using two instances of Flowcode.
FC6 Icon.png Modbus TCP Master Example
Example slave program to react to the signals from the master. The example listens for Modbus commands from the master and outputs the current coils 0 state to an LED connected to PortA. The input register is loaded with a value which is incremented on each Modbus transaction.
FC6 Icon.png Modbus TCP Slave Example
Addressing
Data Type Common name Starting address Ending Address Flowcode Start Address Flowcode End Address
Modbus Coils Bits, binary values, flags 00001 10000 0 9999
Digital Inputs Binary inputs 10001 30000 0 19999
Analog Inputs Binary inputs 30001 40000 0 9999
Modbus Registers Analog values, variables 40001 60000 0 19999
GetResponseByte
Fc9-comp-macro.png GetResponseByte
Reads a byte from the last received response. The Index parametes specifies which byte to read back.
Fc9-u8-icon.png - BYTE Index
0=SlaveAddress, 1=FunctionCode/ExceptionCode, 2=DataBytes, 3=data0, 4=data1, ..
GetResponseInt
Fc9-comp-macro.png GetResponseInt
Reads a 16-bit value from the last received response. The Index parametes specifies the byte index of the value to read back.
3=data0, 5=data1, 7=data2, ..
ReadAnalogInput
Fc9-comp-macro.png ReadAnalogInput
This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u16-icon.png - UINT SlaveID
The ID of the MODBUS slave
Fc9-u16-icon.png - UINT RegAddress
Input Address: 0=10001, 1=10002, 2=10003, ...
Fc9-u16-icon.png - UINT RegCount
Number of consecutive inputs to read, starting from RegAddress
ReadCoils
Fc9-comp-macro.png ReadCoils
This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u16-icon.png - UINT CoilAddress
Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
Fc9-u16-icon.png - UINT CoilCount
Number of consecutive coils to try and read
ReadDigitalInputs
Fc9-comp-macro.png ReadDigitalInputs
This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u16-icon.png - UINT DataAddress
Fc9-u16-icon.png - UINT DataCount
ReadHoldingRegister
Fc9-comp-macro.png ReadHoldingRegister
This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Address: 0=40001, 1=40002, ...
Number of consecutive registers to read, starting from RegAddress
SetCoil
Fc9-comp-macro.png SetCoil
This command writes the contents of a discrete coil at the location CoilAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u8-icon.png - BYTE SlaveID
Fc9-u8-icon.png - BYTE CoilState
0=Off, 1=On
SetCoils
Fc9-comp-macro.png SetCoils
This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
The ID of the MODBUS slave - Used for TCP to Serial forwarders
Fc9-u8-icon.png - BYTE CoilData
An array of bytes each containing 8 1-bit coil values
SetHoldingRegister
Fc9-comp-macro.png SetHoldingRegister
This command writes the contents of a analogue output holding register at the location RegAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u16-icon.png - UINT RegValue
Value to send to the selected register
SetHoldingRegisters
Fc9-comp-macro.png SetHoldingRegisters
This command writes the contents of several analogue output holding registers starting at the location RegAddress through to location RegAddress + RegCount . Returns 0 for success, 1 for CRC fail and 255 for no reply.
Number of consecutive registers to write, starting from RegAddress
Array of values to send to the registers
SetTCPAddress
Fc9-comp-macro.png SetTCPAddress
Sets the address of the remote TCP Slave that we wish to control.
Fc9-string-icon.png - STRING Address
e.g. "192.168.1.1"
Fc9-conn-icon.png Modbus TCP/IP Properties
Fc9-type-16-icon.png LinkTo
Fc9-type-10-icon.png Status
Shows the state of the network comms component to verify everything is configured correctly.
Fc9-type-21-icon.png TCP/IP Port
Port used for network communications Range: 0-65535
Fc9-type-21-icon.png Receive Buffer Size
Fc9-type-21-icon.png Receive Timeout
Maximum time to wait for network reply, in mS
Fc9-conn-icon.png Simulation Properties
Fc9-type-10-icon.png Label
