Component: Timer (Timing)
| Version | 1.1 |
| Category | Timing |
Timer component
Allows you to measure the passage of time via the use of a hardware timer peripheral. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds, Microseconds and also Floating Point and String.
Please click here to download the component source project: FC_Comp_Source_TimerComponent.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponent.fcfx
GetCountMicroSeconds
| GetCountMicroSeconds | |
| Returns the count value as a number of whole microseconds, rounded down to the nearest microsecond | |
GetCountMilliseconds
| GetCountMilliseconds | |
| Returns the count value as a number of whole milliseconds, rounded down to the nearest millisecond | |
GetCountReal
| GetCountReal | |
| Returns the count value as a floating point value in seconds. | |
GetCountSeconds
| GetCountSeconds | |
| Returns the count value as a number of whole seconds, rounded down to the nearest second | |
GetCountString
| GetCountString | |
| Returns the count value as a floating point string in seconds. | |
| Precision | |
| Number of decimal places to display in string | |
GetRawCount
| GetRawCount | |
| Efficient command to collect the integer number of instructions since the timer was started. | |
ResetCounter
| ResetCounter | |
StartCounter
| StartCounter | |
| Starts the timer counting. | |
| ResetCounters | |
| Range: 0-1 where 0=Do Not Reset and 1=Reset | |
StopCounter
| StopCounter | |
| Stops the timer counting. | |
