| Author
Matrix TSL
| Version
1.1
| Category
Timing
Timed Interval component
Allows you to setup a specific timed interval via the use of a hardware timer peripheral. Useful for regular time accurate periodic polling and sampling.
Please click here to download the component source project: FC_Comp_Source_TimerIntervalComponent.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerIntervalComponent.fcfx
StartTimerInterval
StartTimerInterval
| Starts the timer interval.
StopTimerInterval
StopTimerInterval
| Stops the timer interval.
Interval Properties
Time Unit
| Unit of time used for the time period. For example you might want every 4 milliseconds or every 3 hours.
Time Period
| Value of time used for the time period. For example you might want every 4 milliseconds or every 3 hours.
Estimated Best Period
| The closest we can get to the required time period based on prescaler and postscaler settings. Smaller scalers provide finer resolution but impose limits on the maximum delay.
Max Time Measurement
| The maximum time we can do based on the current timer and scaler settings.
Callback Macro
| User defined macro automatically called on a periodic basis.
Timer Properties
Timer
| Timer Peripheral to use to monitor the passage of time.
Bit Depth
| Number of bits in the timer peripheral. 8-bit timers can count from 0-255 before overflowing. 16-bit timers can count from 0 to 65535 before overflowing.
Prescaler
| Scaler applied to the timer, Small scalers allow for finer resolution but will limit the max time and also put more load on the microcontroller. Recommended to use as large a setting as possible which still provides enough accuracy.
PostScaler
Timer Delay (ms)
| Number of milliseconds between timer events which increment the simulated timer counter variable. 10ms will yield the highest resolution. Values less than this will likely just increase the error and making the timer run slow. Higher delays will yield greater accuracy.
