Component: WLAN (EB069-00-2, RN171) (RN171) (Wireless)
Revision as of 13:13, 7 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.1
Category Wireless
WLAN (EB069-00-2, RN171) component
Wireless LAN component designed to work with the RN171 module from Microchip. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069-00-2 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN-RN171_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN-RN171_Dummy.fcfx
Simple playback example - allows a wav file to be streamed out using PWM. Repeats the playback in a loop.
WAV Playback
Simple recording example - allows a wav file to be recorded from a microphone connected to an ADC input pin. Records for approx 10 seconds.
WAV Record
CheckForPageRequests
ConnectToSSID
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 0 if successful.
- STRING SSID
- STRING Key
DisableCommandMode
DisableCommandMode
Exits command mode
EnterCommandMode
EnterCommandMode
Attempts to leave data mode and enter command mode
GetInValue
GetInValue
- BYTE index
Index of the request paramter, starting at zero.
- STRING Return
GetReply
GetReply
Returns the last received response to a command. 0 = OK 1 = FAIL_ERR 2 = STX_ERR 3 = CMD_ERR 4 = PARAM_ERR 5 = ETX_ERR 6 = SERIAL 255 = TOUT
Initialise the device with the property data. Returns 0 if successful
ReadConnectionStatus
Checks the connection status. Returns 0 if not connected, 1 if connected.
ReceiveIncoming
ReceiveIncoming
Returns the received data string
- STRING Return
SendCommand
SendCommand
Sends the given command and returns the reply status. (See GetReply for return values)
- STRING Command
SendString
SendString
Sends the given Text. Appends a CR/LF pair of characters it CrLf is true.
- STRING Text
- BYTE CrLf
SetOutValue
SetOutValue
- BYTE index
- STRING value
