| Author | Matrix Ltd |
| Version | 1.4 |
| Category |  |
Potentiometer (Panel) component
Analogue potentiometer with chicken head style pointer.
Please click here to download the component source project: FC_Comp_Source_pot_Panel.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_pot_Panel.fcfx
 Potentiometer Example
|   | Properties |
|   | Simulation |
|   | Start Angle |
| Angle the control points to at its lowest setting.  Measured counter-clockwise from the positive x-axis. |
|   | Sweep Angle |
| Angle through which the control sweeps as it turns from minimum to maximum. |
|   | Scope Traces |
| Selects if the scope traces are automatically generated or not |
|   | Retain Value |
| If yes is slected After saving your project,  the ADC value will be retained when your project is reloaded. |
|   | Connections |
|   | Channel |
| Analogue input channel - which pin is the analogue input conected to? |
|   | Settings |
|   | VRef voltage |
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V |
|   | VRef option |
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage. VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage. |
|   | Conversion speed |
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock. |
|   | Acquisition cycles |
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample. |
|   | Bit Depth |
| Maximum number of digital bits the ADC can sample. 8 bit = ADC range 0 - 255 10 bit = ADC range 0 - 1023 12 bit = ADC range 0 - 4095 |
