Selecting Compiler Options (ESP)
Options list
Substitute variables used by Flowcode are the same for all platforms.
Compiler
Compiler location
Sets the location of the file controlling compilation
Default:
$(fcddir)ESP\Batch\esp32_build.bat
Compiler parameters
Adds command line parameters when called from Flowcode
Default:
"""$(compileresp)" "$(target)" "$(outdir)" esp32_sdkconfig
Linker/Assembler
Linker/Assembler location
Sets the location of the file controlling linking and assembly
Default:
$(appdir)tools\DoNothing\DoNothing.exe
Linker/Assembler parameters
Default:
<empty>
There are no default parameters
Programmer
Programmer location
Sets the location of the file controlling the programming of the target device
Default:
$(fcddir)ESP\Batch\esp32_prog.bat
Programmer parameters
Default:
"$(compileresp)" "$(target)" "$(outdir)"  $(comport) 115200
Use programmer to set configuration options
This box should be left unchecked
Configuration parameters
This box should be left empty. Configuration parameters are set and downloaded from the Build > Configure menu.
