Component: Numeric Display 2D (Indicators)
Revision as of 13:32, 17 May 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Indicators
Numeric Display 2D component
Allows a numeric value to be displayed on the user panel using virtual 7 seg displays. Used for displaying the value of a variable during simulation runtime. Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
Please click here to download the component source project: FC_Comp_Source_7SegNumeric2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_7SegNumeric2d.fcfx
DisplayAsInt
DisplayAsInt
Displays an integer value on the label. Capable of displaying positive and negative values.
- LONG Value
Integer value to display
DisplayAsReal
DisplayAsReal
Displays a floating point value on the label with a confiiguarable number of decimal points
- FLOAT Value
Real floating point value to display
- BYTE Precision
Number of decimal point values to show e.g. 2 = 0.00
SetBackgroundColour
SetBackgroundColour
Allows the user to manually specify the default colour of the background.
- LONG Colour
RGB colour in the hexadecimal form 0xBBGGRR
SetForegroundColour
SetForegroundColour
Allows the user to manually specify the default colour of the foreground text.
- ULONG Colour
Title
Show Title
Decides if the title is shown on the panel.
Title Text
Specifies the title displayed on the panel.
Title Scale
Specifies the size of the title on the panel, default 1.2
Title Colour
Specifies the font colour for the item
Title Offset X
Horizontal distance from the centre of the component to draw the title
Title Offset Y
Distance above component center to draw the title
Display Properties
Number of Digits
Number of digits in the indicator. The number of digits sets the range available For example 4 Digits can display 0000 to 9999, out of range items will be shown as - - - -
Colour Ranges
Allows ranges to be specified to automatically format the foreground and background colours based on the numeric value
Defaults
Foreground On Colour
The label foreground Text colour
Background Colour
The label background Surrounding colour
Range 1
Min Value
The minimum value to meet the range condition ( >= )
Max Value
The maximum value to meet the range condition ( < )
Foreground Colour
The label foreground Text colour when in the specified range
Background Colour
The label background highlight colour when in the specified range
Range 2
Min Value
Max Value
Foreground Colour
Background Colour
Range 3
Min Value
Max Value
Foreground Colour
Background Colour
Range 4
Min Value
Max Value
Foreground Colour
Background Colour
Range 5
Min Value
Max Value
Foreground Colour
Background Colour
