Mathematical Functions
Revision as of 10:50, 7 August 2023 by BenR (talk | contribs)
See Calculation Icon Properties
The following mathematical functions can be used in calculations. All of these functions are now usable on each chip type.
Functions
Flowcode includes an additional set of mathematical functions:
Function Prototype Description
float = fadd(float, float) Add two floating point numbers together
float = fsub(float, float) Subtract two floating point numbers
float = fmul(float, float) Multiply two floating point numbers
float = fdiv(float, float) Divide two floating point numbers
float = fmod(float, float) MOD function for floating point numbers
byte = isinf(float) Checks to see if the floating point number is infinite
byte = isnan(float) Checks to see if the floating point is not a number
byte = float_eq(float, float) Compares two floating point numbers to see if they are equal
byte = float_ge(float, float) Compares two floating point numbers to see if they are greater then or equal
byte = float_gt(float, float) Compares two floating point numbers to see if they are greater then
byte = float_le(float, float) Compares two floating point numbers to see if they are less then or equal
byte = float_lt(float, float) Compares two floating point numbers to see if they are less then
int = random() Generates a random number 0x0000 <=> 0xFFFF
fabs( x ), floor( x ), ceil( x ) Absolute value, floor and ceiling functions
fmod( x , y ) Floating point modulus (remainder of x divided by y)
sqrt( x ), cbrt( x ) Square and cube roots
log( x ), log10( x ) Logarithms (base e and base 10)
exp( x ), pow( x , y ) Exponential and power functions (x to the power of y)
sin( x ), cos( x ), tan( x ) Trigonometric functions where x is in radians
asin( x ), acos( x ), atan( x ) Inverse trigonometric functions where x is in radians
atan2( y , x ) Four-quadrant inverse tangent
sinh( x ), cosh( x ), tanh( x ) Hyperbolic functions
isnan( x ), isinf( x ) Tests for not-a-number and infinity
round( x ) Decimal rounding (x rounded to the nearest integer)
fround( x , y ) Floating point rounding (x rounded to y decimal places)
asinh( x ), acosh( x ), atanh( x ) Inverse hyperbolic functions
fact( x ) Factorial
SetPinNoDDR( PortPin, Output ) Set output pin quickly without changing data direction state.
Input = GetPinNoDDR( PortPin ) Read input pin quickly without changing data direction state.
