| Author
Matrix TSL
| Version
2.3
| Category
E-blocks 2
TCP/IP component
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here to download the component source project: FC_Comp_Source_TCPIP_BL0187.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_BL0187.fcfx
ControlLEDs
ControlLEDs
| Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly.
- BYTE
Mode
| 0=Off, 1=On, 2=Auto
CreateIPSocket
CreateIPSocket
- BYTE
| Specifies the communications channel 0-3
- BYTE
Protocol
| Specifies which IP protocol to use
- BYTE
Broadcast
| Allows broadcast type packets to be sent and received
- BYTE
CreateMACSocket
CreateMACSocket
| This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE
Promiscuous
| Receive everything (1) or just data bound for your MAC (0)
- BYTE
Broadcast
| Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE
Error
| Allowsmessages with errors to be accepted (1) or rejected (0)
- BYTE
CreateTCPSocket
CreateTCPSocket
| This macro creates a socket for sending and receiving TCP data.
- BYTE
- UINT
Src_Port
| Port Number
- BYTE
CreateUDPSocket
CreateUDPSocket
| This macro creates a socket for sending and receiving UDP data.
- BYTE
- UINT
Src_Port
| Port Number
- BYTE
DHCP_Setup
DHCP_Setup
- BYTE
DNS_Lookup
DNS_Lookup
| Resolve the URL into an IP address via the DNS server. Returns non-zero if successful
- STRING
URL
| URL address string
- BYTE
IP
| Returned IPv4 address
- BYTE
GetLocalIP
GetLocalIP
| Gets the local IP address
- BYTE
IP
| 4-byte Array to store the IP address
GetLocalMAC
GetLocalMAC
| Gets the local MAC address
- BYTE
MAC
| 6-byte Array to store the MAC address
| Initialises the SPI connection to the TCPIP module and sets up some initial values. Flashes the LEDs on and off twice to confirm SPI comms are active. LEDs are then configured to auto functionality.
ReadRegister
ReadRegister
| Reads the value from a single register onboard the ENC28J60 module.
- BYTE
Address
- BYTE
RxDataAvailable
RxDataAvailable
| Check if data has been received. A non-zero return value indicates that data is available. This macro should be called regularly as it also processess supporting network traffic.
- BYTE
- BYTE
RxDataSize
RxDataSize
| This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE
- UINT
RxFlushData
RxFlushData
| Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE
RxMatchMyIP
RxMatchMyIP
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE
- BYTE
RxMatchMyMAC
RxMatchMyMAC
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE
- BYTE
RxMatch_2_Bytes
RxMatch_2_Bytes
| This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
| Specifies the value of the first byte
- BYTE
Byte2
| Specifies the value of the second byte
- BYTE
RxMatch_4_Bytes
RxMatch_4_Bytes
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
| Specifies the value of the third byte
- BYTE
Byte4
| Specifies the value of the fourth byte
- BYTE
RxMatch_6_Bytes
RxMatch_6_Bytes
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
| Specifies the value of the fifth byte
- BYTE
Byte6
| Specifies the value of the sixth byte
- BYTE
RxReadByte
RxReadByte
| A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
RxReadHeader
| Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE
- BYTE
Idx
| Specifies the byte index to return
- BYTE
RxReadString
RxReadString
| A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Length
- STRING
RxSkipBytes
RxSkipBytes
| Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE
- BYTE
Count
| Specifies how many bytes to skip
RxStart
RxStart
| Move the received buffer read pointer back to the start
- BYTE
SetDestination
SetDestination
| This is used in IP and UDP modes to set the destination of the intended data transfer.
- BYTE
- BYTE
IP
- UINT
Port
| Destination Port
- BYTE
SetGateway
SetGateway
| This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
| First Byte of IP address
- BYTE
IP1
| Second Byte of IP address
- BYTE
IP2
| Third Byte of IP address
- BYTE
IP3
| Fourth Byte of IP address
SetLocalIP
SetLocalIP
| This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
SetMACAddress
SetMACAddress
| Allows the MAC Address specified in the component properties to be overridden. The MAC Address will revert back to the MAC specified in the component properties as part of the initialise macro.
- BYTE
MAC0
| MAC Address Parameter
- BYTE
MAC1
- BYTE
MAC2
- BYTE
MAC3
- BYTE
MAC4
- BYTE
MAC5
SetSubnetMask
SetSubnetMask
| This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TCP_Close
TCP_Close
| When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE
TCP_Connect
TCP_Connect
| This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- STRING
URL
| URL or IPv4 address
- UINT
Dst_Port
| Destination Port
- BYTE
TxEnd
TxEnd
| Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE
TxSendByte
TxSendByte
| This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE
- BYTE
Data
| Data byte to append to Tx buffer.
TxSendMyIP
TxSendMyIP
| This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE
TxSendMyMAC
TxSendMyMAC
| This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE
TxSendString
TxSendString
| This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE
- STRING
Data
- BYTE
Length
TxStart
TxStart
| This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE
WriteRegister
WriteRegister
| Writes a value to a single register onboard the ENC28J60 module.
- BYTE
Address
- BYTE
Data
TCP IP Specifics
Server Port
| Sets the server's TCP/IP port address which is used to filter incoming TCP packets.
Buffer Size
| Number of bytes to use for the transmit and receive buffer, we actually use this +1 to allow for a null termination. 8-bit PICs should set this to 255 to allow compilation to succeed. Other devices can have larger buffers. Default = 500
SPI Settings
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Reset Pin
LED Flash
| When enabled the socket LEDs will flash on/off 500ms. Useful for SPI check.
Auto DHCP
| When enabled the Initialisation will also include DHCP setup to auto configure settings.
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
IP Address
IP0
IP1
IP2
IP3
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
Sim Type
| Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / Injector - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
SPI Simulation
API
