Component: Touch Screen (GT911) (Graphical Library)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Graphical Library
Touch Screen (GT911) component
Low level routines for controlling or interacting with the GT911 touch screen controller IC found on a lot of common capacitive touch screen products.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_GT911.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_GT911.fcfx
Fc9-comp-macro.png Initialise
Activates the SPI peripheral and claims control over the I/O pins. Returns 1 if device found and communicating.
ReadCoord
Fc9-comp-macro.png ReadCoord
Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
Fc9-u8-icon.png - BYTE Coordinate
0 = X, 1 = Y, 2 = PointSize, 3= TrackID
Fc9-u8-icon.png - BYTE Index
Touch Index Range: 0 - 1
ReadXBytes
Fc9-comp-macro.png ReadXBytes
Reads the specified number of bytes starting at the specified address
Fc9-u16-icon.png - UINT Address
Fc9-u8-icon.png - BYTE Data
Fc9-u8-icon.png - BYTE NumBytes
SampleSensor
Fc9-comp-macro.png SampleSensor
Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Single touch detected, 2 = Two touch points detected
WriteXBytes
Fc9-comp-macro.png WriteXBytes
Writes the specified number of bytes starting at the specified address
Fc9-type-16-icon.png LinkTo
Fc9-conn-icon.png Bus Settings
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-16-icon.png Device Address
The device address is set using the INT pin on power up. Low = 0x5D / High = 0x14
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-type-5-icon.png Reset Pin
Pin used to reset the touch module
Fc9-type-5-icon.png INT Pin
Pin used to set the I2C address and check for new touch data.
Fc9-conn-icon.png Configuration
Fc9-type-16-icon.png Analogue Mode
Fc9-type-21-icon.png X Pixel
Fc9-type-21-icon.png Y Pixel
Fc9-type-7-icon.png Flip X
Fc9-type-7-icon.png Flip Y
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Label used to identify the component on the panel.
Fc9-type-7-icon.png Enable Interrupt
Fc9-type-22-icon.png Interrupt Macro
Macro called when the simulated display fires an interrupt.
Allows the I2C communications to be simulated and piped through an API to real world hardware.
