Component: Array Helper ( Data)
Revision as of 10:57, 28 November 2023 by BenR (talk | contribs) (→Examples)
Author MatrixTSL
Version 0.1
Category Data
Array Helper component
Component designed to allow manipulation of Javascript arrays.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Array.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Array.fcsx
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
Web Weather Example
ArrayAddValue
ArrayAddValue
Adds an element to a JavaScript array object. Returns the new size of the array.
- HANDLE Object
The JavaScript object
- ULONG Index
The element index
- HANDLE Element
The new element to add to the array
- LONG Return
ArrayGetLength
ArrayGetLength
Gets the length of a JavaScript array object
- HANDLE Object
- LONG Return
ArrayGetValue
ArrayGetValue
Gets the value of an element in a JavaScript array object
- HANDLE Object
- ULONG Index
The element index
- HANDLE Return
ArrayIndexOf
ArrayIndexOf
Gets the index of a value within a JavaScript array object
- HANDLE Object
- HANDLE Value
The value to look for within the array
- INT Start
The index to start the search (use negative numbers to search backwards)
- LONG Return
ArrayParse
ArrayParse
Parse a JavaScript array object by calling the macro for each element in the array.
- HANDLE Object
ArrayRemoveValues
ArrayRemoveValues
Removes elements from a JavaScript array object. Returns the new size of the array.
- HANDLE Object
- ULONG Index
The element index
- ULONG Count
The number of values to remove from the array
- LONG Return
ArraySetValue
ArraySetValue
Sets the value of an element in a JavaScript array object
- HANDLE Object
- ULONG Index
The element index
- HANDLE Value
The new value for the array element
IsArray
IsArray
Returns true if the JavaScript object is an array
- HANDLE Object
- BOOL Return
ParseArray macro
Allows an easy way to parse an array element by element
