Component: HTTP Fetch ( Comms)
Revision as of 15:04, 1 December 2023 by BenR (talk | contribs) (→Examples)
Author MatrixTSL
Version 0.1
Category Comms
HTTP Fetch component
Component designed to request resources from an external HTTP server.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Fetch.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Fetch.fcsx
HTTP
Example program showing how to retreive the HTML source of a HTTP URL.
Fetch HTTP Example
The HTML source is hosted at the following URL: http://www.flowcode.co.uk/examples/fetchtest.txt
File:fetchtest.txt
HTTP JSON Encoded
Example program showing how to retreive the HTML source of a HTTP URL. Here the source is encoded JSON data which we can parse through.
Fetch HTTP JSON Example
The HTML source is hosted at the following URL: www.flowcode.co.uk/examples/jsonfetchtest.txt
File:jsonfetchtest.txt
HTTP JSON Encoded Time and Date
Example program showing how to retreive the HTML source of a HTTP URL. Here the source is encoded JSON data which we can parse through. The data is created using a PHP script which allows for dynamic data such as the current time and date.
Fetch HTTP Time Date Example
The HTML source is hosted at the following URL: www.flowcode.co.uk/examples/jsonfetchtimedate.php
Please note the file type for the file below has been changed from .php to .txt to be allowed onto the Wiki.
File:jsonfetchtimedate.txt
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
Web Weather Example
Fetch
Fetch
Start the process of fetching a resource from a web server
- STRING sParams
Parameters for the Fetch call
SetMacro
SetMacro
- STRING sMacro
SetURL
SetURL
Sets the URL for the Fetch call
- STRING sURL
URL
Call macro
