| Author
Matrix Ltd
| Version
1.9
| Category
Graphical Monochrome
GLCD (SSD1327) I2C component
Graphical display component based on the I2C version of the SSD1327 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1327_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1327_I2C.fcfx
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
ControlDisplay
ControlDisplay
| Allows the display to be switched on and off
- BYTE
Control
| 0=Off, 1=On
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
InvertDisplay
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
Refresh
Refresh
| Refreshes the entire display by sending the contents of the local RAM to the display at high speed
SendCommand
SendCommand
- BYTE
Command
SetBackgroundColour
SetBackgroundColour
- BYTE
PixelColour
| 0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
PixelColour
| 0=White, 1=Black
SetShadeIntensity
SetShadeIntensity
| Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE
Shade
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Flip
| Determines if the display is flipped or not
Auto Draw
| Yes: Default - Lines, Text, Clear will all be done automatically No: Data will be sent only to the internal RAM, the display will be updated using the Refresh command
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
I2C Address
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Simulate Comms
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
