Component: GLCD (ST7789V) (Graphical Color)
Revision as of 14:29, 1 March 2024 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
GLCD (ST7789V) component
Graphical display component designed to work with the ST7789V 16-bit colour graphical controller IC.
BPlot
BPlot
- UINT X1
- UINT Y1
BacklightOff
BacklightOff
Switches off the backlight
BacklightOn
BacklightOn
Switches on the backlight
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
DrawRoundedRectangle
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
Window
Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
X Offset
Horizontal offset before the active display pixels.
Y Offset
Vertical offset before the active display pixels.
Colour
Monochrome
Foreground Color
Background Color
Invert Colours
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Use SPI
No - Use dedicated IO pins to drive the display Yes - Use the micrcontroller's SPI peripheral to drive the display
Data
Data pin connection
Clock
Clock pin connection
Use CS
Toggle CS
Selects if the chip select pin is automatically toggled or left selected. Yes - Slightly slower but allows pins to be multiplexed with other devices. No - Slightly faster.
Chip Select
Chip select pin connection
Use Reset
Reset
Reset Pin
Use Backlight
Backlight
Backlight Pin
Use DC Pin
Selects if the DC pins is available, Yes we use the DC pin to control if a data or commnd is being sent. No we add an extra bit to the data to do the job of the DC pin.
DC
Data/Command Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7789V.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7789V.fcfx
