| Author
Matrix Ltd.
| Version
2.7
| Category
File
File (ESP32 SDMode) component
File component allowing access to read and write files on an SD card using the ESP32 SD Mode IO allowing for high speed data transfer using 1-bit or 4-bit SD access.
Line Following
Line following example using the Formula AllCode, works with objects on the simulation panel and on the real hardware.
FA-Line
Simulation with the API component
An example showing how to use the API component to drive the robot in simulation.
FA API Sim Demo
AppendByteArrayToFile
- BYTE
Data
- UINT
Length
- BYTE
AppendByteToFile
AppendByteToFile
- BYTE
Data
- BYTE
AppendFloatArrayToFile
| Adds a binary float array to the end of the file. Returns 0 for success.
- FLOAT
Data
| Binary data array to append to the file
- UINT
Length
| Number of values to append
- BYTE
AppendINTArrayToFile
| Adds a binary INT array to the end of the file. Returns 0 for success.
- UINT
Data
- UINT
Length
- BOOL
MSBFirst
| 0=LSB then MSB, 1=MSB then LSB
- BYTE
AppendLongArrayToFile
| Adds a binary Long array to the end of the file. Returns 0 for success.
- ULONG
Data
- UINT
Length
- BOOL
MSBFirst
- BYTE
AppendStringToFile
AppendStringToFile
- STRING
Data_String
- BYTE
CloseFile
CloseFile
CreateFile
CreateFile
- STRING
Filename
- BYTE
DeleteFile
DeleteFile
- STRING
Filename
- BYTE
| Starts up the SD card interface and checks to see if a card is compatible. Returns: 0=OK, 255=No Card, 254=File System Fail
- BYTE
MoveToNextFileSector
| Not currently implemented on the RPI
- BYTE
ForceNextSector
- BYTE
OpenFile
OpenFile
| Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
- STRING
Filename
| 8.3 filename of the file we are trying to open e.g. "file.txt"
- BYTE
OpenFolder
OpenFolder
- STRING
Folder_Name
- BYTE
ReadByteArrayFromFile
| Reads a binary byte array from the currently open file. Auto increments the position in the file. Returns the number of values read.
- BYTE
Data
- UINT
Length
- UINT
ReadByteFromFile
ReadByteFromFile
| Reads a byte from the currently open file. Auto increments the position in the file. A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
- BYTE
ReadByteFromIndex
ReadByteFromIndex
| Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer.
- ULONG
Address
- BYTE
ReadFileLength
ReadFileLength
- INT
ReadFileSize
ReadFileSize
| Reads the entire size of the current file in bytes.
- ULONG
ReadFloatArrayFromFile
| Reads a binary Float array from the currently open file. Auto increments the position in the file. Returns the number of values read.
- FLOAT
Data
| Data variable to populate with data
- UINT
Length
| Number of values to read
- BOOL
MSBFirst
- UINT
ReadINTArrayFromFile
| Reads a binary INT array from the currently open file. Auto increments the position in the file. Returns the number of values read.
- UINT
Data
- UINT
Length
- BOOL
MSBFirst
- UINT
ReadLongArrayFromFile
| Reads a binary Long array from the currently open file. Auto increments the position in the file. Returns the number of values read.
- ULONG
Data
- UINT
Length
- BOOL
MSBFirst
- UINT
ReadStringFromFile
ReadStringFromFile
| Reads a string from the currently open file. Auto increments the position in the file. An empty string signifies the end of the file has been reached.
- UINT
NumBytes
| Maximum number of bytes to attempt to read
- BYTE
EndChar
| Ends the string if the value specified is found, default is 0
- STRING
SetFileIndex
SetFileIndex
- BYTE
File_Index
| Range: 0 to 4
Uninitialise
Uninitialise
| Terminates connection to the SD card, unmounts the SD card and disabled the SD peripheral.
WriteByteToBuffer
WriteByteToBuffer
- UINT
Address
- BYTE
Data
WriteFileSector
WriteFileSector
- BYTE
Frequency
File Count
| Number of simultaneous files we want to access.
SD Mode
Buffer Size
| Number of bytes to use as a read buffer to speed up file access.
Directory Size
| Number of bytes to use as a directory buffer to track the current directory.
Pins
CLK
CMD
D0
D1
D2
D3
Sim Root Folder
Please click here to download the component source project: FC_Comp_Source_File_ESP32_SDMode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_ESP32_SDMode.fcfx
