Component: SerialPort ( Comms)
Revision as of 08:53, 14 May 2024 by BenR (talk | contribs) (→Examples)
Author MatrixTSL
Version 0.1
Category Comms
SerialPort component
Allows connection to a serial port e.g. a standard serial COM port from the browser.
Simple Data
Example program showing how to use communicate to a standard serial COM port.
Web Serial Port Example
Close
Close
Closes the serial port
GetProductId
GetProductId
Returns the productId of the selected USB COM port
- LONG Return
GetVendorId
GetVendorId
Returns the vendortId of the selected USB COM port
- LONG Return
Open
Open
Attempts to open a serial port that has already been selected using RequestPort Returns true if port is successfully opened
- BOOL Return
ReceiveString
ReceiveString
Receives a string from the serial port
- LONG Timeout
Time (in ms) to wait for data
- LONG NumChars
Number of characters to try to receive
- STRING Return
RequestPort
RequestPort
Asks the user which serial port to use. Returns the selected COM port as a hex string in the form 0xVVVVPPPP where VVVV and PPPP are the vendorID and productID of the USB device.
- STRING Return
SendString
SendString
Sends a text string through an open serial port
- STRING sText
Comms Settings
The baud rate for the serial communication
Custom Baud
A custom baud rate that is not limited to those in the drop-down list (must be a positive integer greater than 0)
Data Bits
Data bits per frame (default = 8)
Stop Bits
Number of stop bits at the end of a frame (default = 1)
Parity
The parity mode for serial communication (default = none)
Buffer Size
Size of the read and write buffers used (default = 255) (must be an integer greater than 0)
Flow Control
The flow control mode for communication (default = none)
Filters
Limits the list of available COM ports to specific USB devices, for example: { usbVendorId: 0x2A03, usbProductId: 0x0043 }, { usbVendorId: 0x2341, usbProductId: 0x0043 }, { usbVendorId: 0x2341, usbProductId: 0x0001 } (leave blank for all COM ports)
Please click here to download the component source project: FC_Comp_Source_WEBEXP_SerialPort.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_SerialPort.fcsx
