Component: GLCD (SSD1305) (SSD1305) (Graphical Monochrome)
Version 1.8
Category Graphical Monochrome
GLCD (SSD1305) component
Graphical display component based on the SSD1305 monochrome graphical controller IC.
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
Dimensions
Pixel Width
Pixel Height
H Offset
Offset from the edge of the display, default 0.
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Chip Select (CS)
Chip select pin connection
Read / Write (R/W)
Reg Select (RS)
Data (SD)
Serial Clock (SCK)
Reset pin connection
Reset (RST)
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
User Label Text
Text to display
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1305.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1305.fcfx
