Component: CSV Read/Write (File)
Revision as of 09:14, 16 July 2024 by Wiki bot (talk | contribs)
Category File
CSV Read/Write component
A component to simplify the task of creating and dumping data to a CSV file that can be loaded into Microcoft Excel or LibreOffice Math to create nice charts and graphs. Requires one of the File components to provide access to the file system.
Simple example file to generate a two column CSV file that can be loaded into Microsoft Excel or LibreOffice Math.
The CSV Read/Write component is for simulation or App Developer.
For an embedded CSV read write see the File component
CSV Component used with App Developer -> File component: FC6 Icon.png CSV Test AD
The component requires linking to a File component to provide access to the file system for simulation and runtime, this could be the File SD, File RPI or File AppDeveloper components.
AddInteger
Fc9-comp-macro.png AddInteger
Adds an integer number to the CSV followed by a comma. This will form a single column of data in the CSV file.
Fc9-s32-icon.png - LONG data
AddNumber
Fc9-comp-macro.png AddNumber
Adds a number to the CSV followed by a comma. This will form a single column of data in the CSV file.
Fc9-f32-icon.png - FLOAT data
AddString
Fc9-comp-macro.png AddString
Adds a string to the CSV followed by a comma. This will form a single column of data in the CSV file.
Fc9-string-icon.png - STRING data
CloseFile
Fc9-comp-macro.png CloseFile
Closes the file and finishes off any pending writes ready for use in an external application.
NextRow
Fc9-comp-macro.png NextRow
Move to the next row in the file
OpenFile
Fc9-comp-macro.png OpenFile
Creates or opens a file ready for streaming data. If the file already exists then the contents will be deleted and the file started again from scratch. Returns 1 if file found and opened.
Fc9-bool-icon.png - BOOL Erase
0=Append existing data, 1=Reset file data
ReadAsNumber
Fc9-comp-macro.png ReadAsNumber
Reads the contents of a cell as a number.
Fc9-u16-icon.png - UINT Column
Fc9-u16-icon.png - UINT Row
ReadAsString
Fc9-comp-macro.png ReadAsString
Reads the contents of a cell as a string
SequentialReadNumber
Fc9-comp-macro.png SequentialReadNumber
Reads the contents of a cell as a number. Automatically moved to the next data cell after a read.
SequentialReadString
Fc9-comp-macro.png SequentialReadString
Reads the contents of a cell as a string. Automatically moved to the next data cell after a read.
SetSequentialIndex
Fc9-comp-macro.png SetSequentialIndex
Sets the index for sequential reads. Index is automatically reset to 0 after a file open.
Fc9-u16-icon.png - UINT Index
Fc9-type-16-icon.png LinkTo
Please click here to download the component source project: FC_Comp_Source_CSV_Writer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CSV_Writer.fcfx
