| Author
Matrix TSL
| Version
1.0
| Category
Analog Input
ADC16bit ADS111x component
A Precision Low power 16Bit I2C ADC 4 channes device with a Programmable comparator
Simple example file to generate a two column CSV file that can be loaded into Microsoft Excel or LibreOffice Math.
The CSV Read/Write component is for simulation or App Developer.
For an embedded CSV read write see the File component
CSV Component used with App Developer -> File component:
CSV Test AD
The component requires linking to a File component to provide access to the file system for simulation and runtime, this could be the File SD, File RPI or File AppDeveloper components.
| Sets up the I2C bus ready for communications with the device. Returned value: 0 = Success
- BYTE
SampleSglRaw
SampleSglRaw
| Performs a single ADC sample on the selected ADC channel
- BYTE
| Range: 0-3
- BYTE
Mode
| Single-Shot Mode - powers down when conversion has finished. Range 0 to 1. 0 = Continuous, 1 = Single-Shot
- BYTE
Gain
| GAIN 0 = 6.144V, 1 = 4.096V, 2 = 2.048V, 3 = 1.024V, 4 = 0.512V 5 = +- 0.256V
- UINT
SampleSglVolts
SampleSglVolts
- BYTE
| Range: 0-3
- BYTE
Mode
- BYTE
Gain
- FLOAT
Device Address
| ADDR connects either to the GDN, VDD, SDA or SCL to determing the address of the ADC.
| Channel selection
SDA
SCL
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
RDY/ALRT
Configuation
Samples Per Sec
Gain A0
| Gain is for simulation only. The hardware ADC gain is set within the function parameter.
Gain A1
Gain A2
Gain A3
Simulate Comms
| Allows the communications to be simulated overriding the value on the panel slider controls.
Please click here to download the component source project: FC_Comp_Source_External_ADC16Bit_ADS111x.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_External_ADC16Bit_ADS111x.fcfx
