Component: Timer (Timing)
Version | 14.0 |
Category | Timing |
Timer component
Allows you to measure the passage of time via the use of a hardware timer peripheral. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds, Microseconds and also Floating Point and String.
Version information
GetCountMicroSeconds
GetCountMicroSeconds |
Returns the count value as a number of whole microseconds, rounded down to the nearest microsecond | |
Return |
GetCountMilliseconds
GetCountMilliseconds |
Returns the count value as a number of whole milliseconds, rounded down to the nearest millisecond | |
Return |
GetCountReal
GetCountReal |
Returns the count value as a floating point value in seconds. | |
Return |
GetCountSeconds
GetCountSeconds |
Returns the count value as a number of whole seconds, rounded down to the nearest second | |
Return |
GetCountString
GetCountString |
Returns the count value as a floating point string in seconds. | |
Precision |
Number of decimal places to display in string | |
Return |
GetRawCount
GetRawCount |
Efficient command to collect the integer number of instructions since the timer was started. | |
Return |
ResetCounter
ResetCounter |
Return |
StartCounter
StartCounter |
Starts the timer counting. | |
ResetCounters |
Range: 0-1 where 0=Do Not Reset and 1=Reset | |
Return |
StopCounter
StopCounter |
Stops the timer counting. | |
Return |
Please click here to download the component source project: FC_Comp_Source_TimerComponent.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponent.fcfx
