Component: I2C Multiplexer (TCA9548A) (Comms: Interface)
Revision as of 09:31, 19 July 2024 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Comms: Interface
I2C Multiplexer (TCA9548A) component
Allows up to eight I2C busses to be multiplexed from a single I2C bus allowing for multiple devices with the same I2C address to be accessed. Up to 8 devices can be used together allowing for a total of 64 of the same devices to be accessed from a single I2C bus.
ChangeAddress
ChangeAddress
Allows the component to communicate with multiple TCA9548A devices by switching the address.
- BYTE Address
Range: 0-7
DisableAll
DisableAll
Disables all 8 channels on the current TCA9548A device.
DisableChannel
DisableChannel
Disables a specific channel on the current TCA9548A device.
- BYTE Channel
EnableAll
EnableAll
Enables all 8 channels on the current TCA9548A device.
EnableChannel
EnableChannel
Enables a specific channel on the current TCA9548A device.
- BYTE Channel
Range: 0-7
ExclusiveChannel
ExclusiveChannel
Enables the selected channel and disables all others on the current TCA9548A device.
- BYTE Channel
Range: 0-7
Starts up the I2C bus and closes all channels.
Channel selection
Device Address
Baud Select
Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
API
Please click here to download the component source project: FC_Comp_Source_TCA9548A_I2C_Multiplexer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCA9548A_I2C_Multiplexer.fcfx
