| Author
Matrix Ltd
| Version
2.0
| Category
Graphical Library
Touch Screen (GT911) component
Low level routines for controlling or interacting with the GT911 touch screen controller IC found on a lot of common capacitive touch screen products.
Version information
6, 1.0, 26-07-24, BR, Removed ghost greay square connection line
| Activates the SPI peripheral and claims control over the I/O pins. Returns 1 if device found and communicating.
- BOOL
ReadCoord
ReadCoord
| Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
- BYTE
Coordinate
| 0 = X, 1 = Y, 2 = PointSize, 3= TrackID
- BYTE
Index
| Touch Index Range: 0 - 1
- UINT
ReadXBytes
ReadXBytes
| Reads the specified number of bytes starting at the specified address
- UINT
Address
- BYTE
Data
- BYTE
NumBytes
- BOOL
SampleSensor
SampleSensor
| Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Single touch detected, 2 = Two touch points detected
- BYTE
WriteXBytes
WriteXBytes
| Writes the specified number of bytes starting at the specified address
- UINT
Address
- BYTE
Data
- BYTE
NumBytes
LinkTo
Bus Settings
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
Device Address
| The device address is set using the INT pin on power up. Low = 0x5D / High = 0x14
SDA
SCL
Reset Pin
| Pin used to reset the touch module
INT Pin
| Pin used to set the I2C address and check for new touch data.
Configuration
Analogue Mode
X Pixel
Y Pixel
Flip X
Flip Y
| Label used to identify the component on the panel.
Enable Interrupt
Interrupt Macro
| Macro called when the simulated display fires an interrupt.
Simulate Comms
| Allows the I2C communications to be simulated and piped through an API to real world hardware.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_GT911.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_GT911.fcfx
